Message 1 of 4
Can't load subscription channels
Hi,
Turned on the TV this morning, and I have lost BT TV and as a consequence all subscription channels.
Others appear to have had the same problem, and have had the issue resolved by mods. Would it be possible for a mod to contact me to sort out this particular problem. Thanks.
3 REPLIES 3
Moderator
Moderator
Message 2 of 4
Re: Can't load subscription channels
Hi @robbo99 and welcome.
I'm sorry you've lost the subscription channels. Are you having any broadband connection problems? Are you seeing any error codes?
Cheers
David
Message 3 of 4
Hi DavidM,
Thanks for contacting me so quickly, it's much appreciated.
I'm not having any internet connection problems, and I haven't seen an error code. As previously mentioned connection to BTTV has simply disappeared. So any help you can provide will be welcome.
Thanks.
Moderator
Moderator
Message 4 of 4
Thanks for getting back @robbo99.
We'll need to take a closer look at this for you so can you drop me over an email with your details? You'll get the contact the moderators link in my profile. We're very busy at present so it's taking longer than expected to reply but once you submit the details we'll get to you in turn.
Cheers
David
