skip_1
Message 1 of 12
Can't record, no errors but program stuck in scheduler
Hi,
We have a problem with our BT You view box.
No shows have recorded since this afternoon. We cannot set to record anything now. We can watch what has been recorded and have some series' that we wish to watch on the recordings and don't want to lose.
Now it seems that I can delete all scheduled shows except one -  Hollyoaks at 18.30 today on C4. I think this may be the issue. A factory reset with keep recordings option has not worked.
Any help appreciated.
11 REPLIES 11
skip_1
Message 2 of 12
Re: Can't record, no errors but program stuck in scheduler
Hoping it will record Hollyoaks and fix itself...
Moderator
Moderator
Message 3 of 12
Hi @skip_1 Sorry you are having a fault with recordings.
Did you get Hollyoaks recorded OK? and if so did it clear the issue?
Cheers
John
skip_1
Message 4 of 12
Unfortunately it didn't work and the problem is persisting. Looks like Image have to try a hard reset ☹️
Moderator
Moderator
Message 5 of 12
Hi @skip_1 Thanks for posting back and sorry to hear it didn't work.
It may be that the hard reset has to be done but if you drop us over your details we will be happy to see if this can be fixed without you having to do this. You can contact us by clicking on my user name and selecting contact the mods.
John
skip_1
Message 6 of 12
JohnC2 - have now done so.
skip_1
Message 7 of 12
All programs now deleted from scheduler. Still cannot set recordings. Looking like a hard reset may be needed 😡
skip_1
Message 8 of 12
Hi John, thanks for making the remote changes to the box. Unfortunately it hasn't worked so a hard reset looks likely. Need to just watch the important recordings now.
Moderator
Moderator
Message 9 of 12
Hi @skip_1
Thanks for posting back and I'm sorry the problem persists.
I can see that @JohnC2 is due to follow up with you again tomorrow.  In the meantime, here is a link to show you how to complete the reset: How do I reset my Youview box from BT?
Cheers,
Robbie
Moderator
Moderator
Message 10 of 12
Hi @skip_1 I called earlier sorry I couldn't reach you. I just wanted to check how you were getting on with watching your recordings before completing the hard reset of the box.
Post back and let me know.
cheers
John
