Foo123
Newbie
Message 1 of 3
Can't record series
YouView has suddenly decided that Pointless is not a series and I can't set a repeated instruction to view, the option to record a series isn't shown. Nothing else displays theis behaviour? Anything I can do?
2 REPLIES 2
gomezz
Recognised Expert
Message 2 of 3
Re: Can't record series
Just tried and it is letting me set it as a series. Which particular episode are you trying to set the record option on?
Foo123
Newbie
Message 3 of 3
Thank you.
Any episode. If I look at the guide for, say, Monday, select Pointless and press the red button to record, it shows the red record indicator next to the programme name. It used to (and for other programmes still does) put up a dialog asking whether I want to record one or the series.
