ajh79
Message 1 of 2
Can you record sky sports on BT youview
Hi,
I've been a sky sports customer for 6 years and had BT for my broadband provider. Thinking of ditching sky and jumping on BT TV saving me around £30.
I just want to clarify that if I have big sport on BT TV will I be able to record sport content?
I used to have youview with talktalk and it was terrible, and I've had no issues with satellite so don't want to return to same problems.
1 REPLY 1
-Richie-
Guru
Message 2 of 2
Re: Can you record sky sports on BT youview
If you subscribe via BT then you can record as the channels will be shown in the EPG, if you're using the NowTV app then you can't record.
So the answer is yes, you can record if you subscribe to Big Sport.
