jenoseel
Message 1 of 2
Cannot hide channels.
How do I hide unwanted channels? I go to Guide, select a channel, click on the yellow button, enter my code number, press the yellow button again, and nothing happens.
1 REPLY 1
barnpiece
Expert
Message 2 of 2
Re: Cannot hide channels.
Did you select the channels you wished to hide?
There is a tick box once you press yellow. Use Select to put a tick.
Do as many channels as you wish then press yellow again.
Richard
