Message 1 of 10
Cannot watch BT Sports programmes on Vision.
I have BT Vision Unlimited and the extra channels on Youview. Also the BT Sports and ESPN all work from the EPG. BT Sports player works on bothe the web and Android app. If I try and watch a BT Sports programme on Vision it says I need to subscribe.
I've tried restarting the box but still won't let me watch, surely there's nothing else I need to subscribe to.
There's a couple of motor races I missed on there I'd like to watch this weekend.
9 REPLIES 9
kevinbrighton
Message 2 of 10
Re: Cannot watch BT Sports programmes on Vision.
For Vision, you need a viewing card, it'll cost you £10.
Message 3 of 10
Sorry but that can't be right. I'm talking about BT Sports on Vision through Youview not BT Sports via a Vision+ box.
The Youview platform doesn't have the facility for viewing DTT encrypted channels with a viewing card.
atlasapl
Message 4 of 10
according to the guide book for the BT Vision box, it states the extra premium sports channels are delivered through your broadband connection.
kevinbrighton
Message 5 of 10
Sorry, thought you meant a Vision+ box. I'll go home now.
Message 6 of 10
All working now, seems it was a common problem. It was on the help page and it was reported as fixed as 13.00 today
DAVEJANINCORNWALL
Message 7 of 10
I CANNOT WATCH BT SPORT DESPITE HAVING A LETTER FROM MR WARREN BUCKLEY HIMSELF (MANAGING DIRECTOR, CUSTOMER SERVICES) SENT AT 11.44 TODAY  WHICH SAID "THANKS FOR CHOOSING BT" (A STATEMENT WHICH MAY HAVE TO BE RETRACTED VERY SOON) "IT SHOULD START WITHIN 15 MINUTES" IT IS NOW 5 AND A HALF HOURS LATER AND STILL NO SIGN OF LIFE.
Distinguished Guru
Distinguished Guru
Message 8 of 10
Yes I had the problem and as of about 5pm it has cleared.
As an aside it does appear that some of the programmes are actually on Demand in both SD and HD versions. The HD versions seem only to be detectable by using search facilitity.
iris32nd
Message 9 of 10
i can't watch sports either and it's 19.45!
Message 10 of 10
The help topic said you might need to restart your box, I didn't need to, though.
