Pip99
Message 1 of 4
Catch Up help
After having problems with channels freezing, I was advised to reset the youview box. This worked after 3 resets, but since then I cannot find the Catch Up tv section on the BT Player. Can anyone help please?
3 REPLIES 3
Moderator
Moderator
Message 2 of 4
Re: Catch Up help
Hi @Pip99,
Have you been able to find it since? If you still can't; take a look at the link below:
On Demand and Catch Up problems on BT TV
Try that for me and let me know how you get on.
DanielS
Community ModeratorDannyS
Show your appreciation!
Kudos”Kudos”
Pip99
Message 3 of 4
Re: Catch Up help
Hi DanielS, no luck so far. I've tried a few things suggested on here, but nothing has worked. The link keeps taking me back to my original question.
Moderator
Moderator
Message 4 of 4
Re: Catch Up help
Thanks for getting back to me @Pip99.
Check the link for me again please, it should be working correctly now Smiley Very Happy
Thank you
DanielS
Kudos”Kudos”
