Tally1001
Message 1 of 6
Catch-up freezing or stuttering
As title Catch-up freezing or stuttering and i have to reboot the box every 2 days, Tv and recording are no problems
My box is connected with a cable to a Tenda MW3 mesh box , the mesh wifi provides a stable 700mb on 5GHZ
and 300mb  on 2.4 GHZ broadband is stable at 67mb down and 20mb up. if i take the cable out of the BTTV box into a laptop i get 60 mb down. Usually rebooting works for a couple of days but uts getting tiresome now.
Its a youview+ box
5 REPLIES 5
gomezz
Recognised Expert
Message 2 of 6
Re: Catch-up freezing or stuttering
700 milli-bits is not very fast. I assume you mean 700Mb?
Tally1001
Message 3 of 6
Yes 700mb . I have done a maintenance reset 2 today and will see how it responds now
gomezz
Recognised Expert
Message 4 of 6
700mb is 1,000,000,000 time slower than 700Mb!
Tally1001
Message 5 of 6
Mb Mb Mb Mb
Tally1001
Message 6 of 6
So i have reset the box keeping recording and its the same on catch-up , i have put a laptop in the cat 5 cable and get 60MB download so its not a broadband issue as daughter can stream Netflix at the same time ok.  Box is 6 months old as other packed in and was replaced.
