davidb00
Message 1 of 2
Changing Logos
Switched on today, played a recording, then viewed the guide, the logos have now changed, for instance the "East Midland BBC1 now shows the channel 5 logo.
I have tried all the usual tricks, change the view to no logo and back again, power switch off for 10 seconds.
 I can live without the logos, but it is just another annoying bug that I will have to put up with until someone sorts out the rest of the problems.
As an aside I tried to show the "5" in large text, it worked in RTF but not in preview
1 REPLY 1
davidb00
Message 2 of 2
Re: Changing Logos
Sorted itself out, switched on after lunch all logos back in their proper places, one of lifes little mysteries, that just leaves the rest of the update to sort out, probably leave that to someone elseSmiley LOL
