Message 1 of 5
Changing channel issue with 4k Youview box
When i turn the box on, the blue line on the device comes on as normal, but the channel takes at least 3 minutes to appear on the TV.
Also when changing channels the screen goes dark and again it takes around 3 minutes before the new channel comes on.
So far i have tried rebooting the box , restarting the router and retuning the TV Channels.
Does anyone have any ideas on this one?
4 REPLIES 4
Moderator
Moderator
Message 2 of 5
Re: Changing channel issue with 4k Youview box
Hi @DKJ1 welcome to the forum and thanks for posting. Sorry that the channel is taking around 3 minutes to appear after you switch channels. I don't have 4K myself but this does sound like it's taking too long.
Have you had 4K long and if so has it done this since the start?
Does this happen even when changing over to a Freeview channel?
cheers
John
Message 3 of 5
Thanks John for your reply
I have had the 4k youview box for around 2 years with no issues , until the above problem started in the last few weeks.
Also yes the problem still occurs when changing from internet channel to freeview channels and vice versa.
I was wondering if a factory reset may help (but possibly this could cause other issues)
Again thanks John
Moderator-Retired
Message 4 of 5
Hi @DKJ1,
Thanks for getting back to us.
Can you check within setting if the box is running the latest firmware?
If the box is running the latest then you would need to factory reset the box to see if this fixes the issue. Normally if this fails to fix the fault we would replace the box.
Matt
Recognised Expert
Message 5 of 5
@DKJ1
Just try a maintenance mode reset - see here for instructions. Options 2 & 4 will keep your recordings , go for option 2 first and then if necessary option 4.
