I have been trying to rent a film from btplayer, but I have never set a pin, and it does not recognise the default pin 1234. I tried resetting my box, but It still doesn't recognise the default pin. How do I reset my pin
Have you clicked on the link that SteaM provided as it takes you to the You view help pages in setting a pin
(If I have helped you in any way please click the thumbs up. Thank You) If I have solved your Issue please click the "Mark as accepted solution" button.
