paulgoode
Message 1 of 12
Channel Unavailable
Hi,
Is anyone else not receiving any internet based services? BT Sports, ESPN all have error code IPC6011, BT Vision on demand loads but every show will not load. iPlayer loads, but the programmes don't play! Anyone know if there are known issues or where I can find out as BT don't have anything about what these codes mean anywhere on there site!
Cheers
Tags (2)
11 REPLIES 11
notoriousdbp
Recognised Expert
Message 2 of 12
Re: Channel Unavailable
Are you using a home hub or an alternative router?
---Remember to mark as 'solved' and give stars when you like a post---
paulgoode
Message 3 of 12
Plugged directly into the home hub!
Distinguished Guru
Message 4 of 12
Which Hub?
BTLife | 1967 Plus Radio | 1000 Classical Hits
Someone Solved Your Question?
Please let other members know by clicking on ’Mark as Accepted Solution’
Helpful Post?
If a post has been helpful, say thanks by clicking the ratings star.
paulgoode
Message 5 of 12
paulgoode
Message 6 of 12
Ok, so that wasn't what i wanted to say! It's an outreach modem attached to a bt home hub. Does that help?
Distinguished Guru
Message 7 of 12
Which home hub?
Helpful Post?
zarf2007
Message 8 of 12
@paulgoode wrote:
Hi,
Cheers
I had this problem occur recently and it was only fixed when i power cycled the white BT openreach modem, my router and then the youview box in that order...
paulgoode
Message 9 of 12
Ok, will try that straight after work. Fingers crossed!!!!
Message 10 of 12
its funny how the codes show on your tv but yet bt dont have the answer online ive got same problem plus another code i wish i hadnt got it its rubbish
