Message 1 of 11
Channel order edit
Is there anyway to change the channel order on the box. I want the HD channels to bet set from channel 1 onwards.
10 REPLIES 10
Recognised Expert
Message 2 of 11
Re: Channel order edit
No.
I use a Harmony universal remote which lets me set up an ordered list of Favourite channels which is an option you may wish to consider.
Message 3 of 11
I would probably be cheaper buying a different box that allows channel edits
Recognised Expert
Message 4 of 11
Good luck finding one of those especially if you want to use it for BT TV / Sport etc channels.
Message 5 of 11
I don't use anything other than normal channels.
I love how BT are kinda harrasing me to send back the old box.
BT TV Expert
Message 6 of 11
Send it back then Smiley Tongue
Message 7 of 11
Nah, that **bleep** might work with old people though.
Recognised Expert
Message 8 of 11
As someone in the category you've just referred to I'm inclined to take offence at that ageist remark.
Recognised Expert
Message 9 of 11
Blimey if you're that bothered, and you haven't got a subscription, just get rid of the flaming thing and get something that covers your needs. Jeeez, you don't need to be a member of MENSA to come to that conclusion.
Message 10 of 11
I'm not that bothered. I commented on it.
I just don't like the way BT try to imply that you need to send it back. You don't.
