Taxboy
Message 1 of 3
Connecting YouView Box with Powerline Adapter
My BT line comes in upstairs and I would like to move the YouView box downstairs to the living room. Ideally I would like to keep the router hub upstairs. Is this possible ?
To try and explain this more clearly can I have the wiring as
Phone Line in ------ Router------Powerline-----YouView Box  or
does it have to be
Phone line in -------Powerline------Router-----YouView Box
Any advice appreciated please
2 REPLIES 2
Distinguished Guru
Message 2 of 3
Re: Connecting YouView Box with Powerline Adapter
No, the.powerlines have to be after the router/homehub
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
Taxboy
Message 3 of 3
Thanks for the quick response. That gives me my preferred option  of home hub upstairs and YouView downstairs
