Davidnic
Message 1 of 3
Connection of Bluray recorder to BT Youview mini box
I was wondering how I connect by bluray recorder to my Youview box. I have the new mini box which doesn't have an aerial out. Do I connect the aerial to my recorder and then out to my youview box? Any help would be appreciated
2 REPLIES 2
Message 2 of 3
Re: Connection of Bluray recorder to BT Youview mini box
You could do that.
The alternative would be to use an aerial splitter, and feed one output to the recorder, and one to the YouView box.
Splitters do introduce a small signal loss, so if you have a poor signal, you may have to use proper distribution amplifier.
The first option would be simpler.
Message 3 of 3
You need to connect the bluray recorder first and then chain the youview box
The bluray recorder will have a tuner and you will have to program it
In general this is not cost effective and you should be looking at upgrading your box to youview+ with hard disk so that you also can program it to record from the internet
