Newbie
Message 1 of 3
Connection to wifi
Hi, I bought a yourview box around a year ago and all was well with set-up.  So i bought another for another room and it insists i need to plug in to my router.  But the other one didn't ask this, and it records, plays etc. well.  I cant find a model number, but the screen is very different.  I did trail a wire from the room to my router and it worked, but refuses to when i removed it again.  I don't want wires trailing all over the house, so how do I get ruond this please?  The first box does not require a wifi connection, and I dont understand that with the newer box, I can record (with router wire removed) but when I try and play back, a message comes up telling me I need to connect to the internet!  Very confusing for me.  Can anyone help me please?  Thanks in advance 🙂 x
2 REPLIES 2
Message 2 of 3
Re: Connection to wifi
Hi @gillymusic. It is very difficult to help you without knowing the make and model of your new Youview box.
Message 3 of 3
Hi @gillymusic.
Instead of trailing wires you could use something like this https://www.shop.bt.com/products/bt-mini-connector-kit-087372-CMS2.html?q=BT%20Mini%20Connector%20Ki...
They are on offer probably from your My BT page or a large selection from other sources.
