Montala
Message 1 of 8
Control Code for BT You View Box?
Hi,
I am not sure if this question has been asked before or not, but can anyone please tell me the four digit control code for the BT You View set top box, so as to enable it to be be operated by another remote control, please?
Many Thanks!
David
7 REPLIES 7
gomezz
Recognised Expert
Message 2 of 8
Re: Control Code for BT You View Box?
That depends on what the other remote control is.
RobbieMac
Moderator
Moderator
Message 3 of 8
Hi @Montala
Thanks for your post and welcome back!
Have you had a look here to find the code for your remote? --> How do I control my TV with my BT TV remote control?
Cheers,
Robbie
gomezz
Recognised Expert
Message 4 of 8
@RobbieMac I think you misunderstand the question.
Montala
Message 5 of 8
Hi Gomezz,
The 'other' remote control will be an "All-for-One" Contour Universal Remote control, and is much quicker to set up if I know the the four digit Control Code for the BT Box.
Montala
Message 6 of 8
Hi Robbie,
Yes... I think so to I'm afraid!
What I am after is just the four digit control code for the latest BT Box!
Regards,
David
gomezz
Recognised Expert
Message 7 of 8
It use the same code-set as other Humax boxes such as the Fox T2 and the Foxsat HDR. If the One-For-All (I think you mean) list of codes mentions those then you are on your way. There will be one or two buttons that you will need to teach the OFA directly though.
NeilO
Moderator
Moderator
Message 8 of 8
Hi @Montala if you google one for all remote codes you'll find the list of Humax codes on their website.
Cheers
Neil
