marco63
Message 1 of 4
Controlling Hitachi TV with remote
Hi. I followed the instructions here https://www.bt.com/help/tv/fix-a-problem/remote-control/how-do-i-control-my-tv-with-my-bt-tv-remote-...
and used the code 2424 for Hitachi
The TV turned off and then on again eventually. I then pressed vol+, vol- and TV AV buttons as instructed,  but nothing happened in response, and then I pressed OK. At the end of this process TV didn’t respond to the remote at all
Can anyone help please?
PS the remote has previously worked with this TV. The other day it stopped working on the BT Box so I reset it. It works fine again for the box, but I can’t get the TV paired again
3 REPLIES 3
marco63
Message 2 of 4
Controlling Hitachi TV with remote - SOLVED
Kept doing the same thing over and over again and the result did change
Emma1967
Message 3 of 4
Re: Controlling Hitachi TV with remote - SOLVED
Hello
I am having a real mare with trying to pair BT TV remote with Hitachi remote  BT even sent out a new remote
What am I doing wrong - I am using 2424 and pressing and holding TV   and TV AV the waiting for the blinking to stop then adding in the code  then pressing and holding TV but the TV doesn't go off
TimCurtis
Recognised Expert
Message 4 of 4
@Emma1967
You're not the only one having this problem today. See this thread for the probable solution.
Edit:seen you had another thread and it's been solved
