dwisdom
Newbie
Message 1 of 5
Controlling SAMSUNG TV with YouView remote
We have just received our Youiew+ box and remote. I have tried to set the YouView remote to control both my SAMSUNG TV and YouView+ box, using intructions in the User Guide, but it doesn't work. I thought it had when I first did it - I was able to change the volume and turn the TV off - but none of the other remote functions worked! I found a post which told me how to reset the remote (press AD, Delete SUB, and BT Player at same time). I tried several times more, holding down the TV button until TV responded, but still no success. Incidentally, when I reset the remote, I can contol the volume from my remote, but can't turn the TV off or on.
4 REPLIES 4
skappy70
Recognised Expert
Message 2 of 5
Re: Controlling SAMSUNG TV with YouView remote
What model TV do you have?
dwisdom
Newbie
Message 3 of 5
Hi. It's LE37A656A1FXXU
skappy70
Recognised Expert
Message 4 of 5
dwisdom
Newbie
Message 5 of 5
Yes = tried this several times.
