benkennedy123
Message 1 of 4
Correct TV aerial cable
Hey everyone, We need to connect our BT TV box to the TV aerial socket in the wall. It looks like a screw on connection of some sort. Does anyone know what the correct cable is called?
3 REPLIES 3
Keith_Beddoe
Message 2 of 4
Re: Correct TV aerial cable
Are you sure its a terrestrial TV connection and not a satellite one?
Its probably one of these https://en.wikipedia.org/wiki/F_connector
This is normally used on satellite dish connections.
You would need an adapter lead to connect it to the YouView box.
gibbylinks
Message 3 of 4
Would it work with an adaptor?
as you said it's probably a satellite dish attached to the other end, which wouldn't work anyway.
NeilO
Moderator
Moderator
Message 4 of 4
BT TV will not pick up the freeview channels through a satellite dish, it needs to be connected to an aerial.
