Newbie
Message 1 of 5
Crime & Investigation Channel 328 - Parental Lock
Hi
Just turned over to 328 and it is asking me for the PIN - I have gone into settings to change the settings but it is still asking me for PIN on the channel.  I haven't set that channel up or any other channel to ask for a PIN. I don't have little kids so no need for any channel to have a PIN.
Does anyone know how to turn off the Parental Controls altogether? I have been in the help section etc
4 REPLIES 4
Distinguished Guru
Distinguished Guru
Message 2 of 5
Re: Crime & Investigation Channel 328 - Parental Lock
Hi @BunnyW
I suspect the channel is showing rated   programing prior to the watershead
see threads like
https://community.bt.com/t5/YouView-from-BT/Parental-Control-Disabled-But-PIN-Still-Required/td-p/17...
Newbie
Message 3 of 5
Hi
Thank you for that, I have had a read but still can't get rid of the parental lock, seems weird its just come on now... its annoying more than anything.
Distinguished Guru
Distinguished Guru
Message 4 of 5
If you havee not set the default parental code  is shown at
https://support.youview.com/youview-box/parental-controls-and-pin/forgotten-your-parental-pin/
along with  reset  advice.
A
Distinguished Guru
Distinguished Guru
Message 5 of 5
Also may be worth assuming you are not recording to restart your  Youview box
ie soft reset/reboot: touch/press the power/standby button on the front/top of the box for about 8 seconds until it starts a reboot.
