Message 1 of 2
DTR-T2100 ethernet network port spec
Hi all,
Would anyone know what  speed spec the ethernet network port on the DTR-T2100 box is?  Is it 100mb or 1gb?
1 REPLY 1
Message 2 of 2
Re: DTR-T2100 ethernet network port spec
Probably 10/100 as even if it was recording two HD streams while watching another on an app, you'd only need around 25Mbps.
