Borse2008
Message 1 of 2
Difference between Old BT Youview and New Branded One?
As per question is there any noticeable difference?
1 REPLY 1
TimCurtis
Guru
Message 2 of 2
Re: Difference between Old BT Youview and New Branded One?
@Borse2008
It depends on which models they are. But in truth the only differences will only be about disk capacity and operational speed, unless the old box is a T1000 which doesn't get software updates these days.
