Recognised Expert
Message 11 of 40
Re: Disappointed new user
Check your router setup, make sure this check box is clear (No Tick) Advanced > Setup > WAN Setup > Disable IGMP Proxying
Message 12 of 40
That was the right route - thanks - I ticked the Bt proxying box and the internet hasn’t dropped in the last five minutes - thanks very much -,Next mission is to get my subscription package to be recognised - should have Bt sports and Liverpool playing soon 😱 I am still unsure as to why I only have a handful of freeview channels but can only guess this is an aerial issue
Recognised Expert
Message 13 of 40
Freeview are frequently adding new channels, re-structuring and moving things around. It might be worth trying a re-tune of your box if channels are missing. Your box gives a good indication of signal quality of the channel you're watching in Settings > TV signal quality. Note that signal quality is more important than strength
Message 14 of 40
@Jonty1993
There is some help with signal levels on this page Picture breakup or missing FreeView channels
You will need to connected to BT Broadband to access this link,  and any other links I post.
BT TV Expert
BT TV Expert
Message 15 of 40
Hi @Jonty1993
Sorry to hear your sports channels are not working for you.
If you PM me your telephone number or account details I can take a look into the issue for you.
Thank you,
Message 16 of 40
The WAN proxy did work thanks - internet hasnt dropped since I checked the allow BT proxying box
Message 17 of 40
Things are looking good - I have 18 aerial and 109 subscription channels along with a proper front end screen - thanks for all your help - Gemma don’t know if you did anything but it all came back during yesterday - I think the really key thing was the router setting - it’s a shame the package ‘assumes’ you have a Bt router as that is a real curve ball - if I didn’t have the nounce to ask on this forum I would be either stuck on five channels and a forever dropping internet link or sending the box back - the one thing I do need to try now is the app as that didn’t work before
Recognised Expert
Message 18 of 40
You should have a lot more than 18 channels over aerial, you should have the same number as if you were watching with the aerial plugged straight into the TV. Have you tried re-tuning the Youview box?
Message 19 of 40
Do you happen to know if your in a freeview or freeview lite area? If your using a relay you’ll likely get less channels but you should still get more than 18. Just to confirm are you using an outdoor or indoor aerial? (Sorry if you’ve posted this already)
Message 20 of 40
Probably meant to be the other way around, typo?
