benwiddowson
Expert
Message 21 of 40
Re: Disappointed new user
Yeh. Sorry Judy got up
benwiddowson
Expert
Message 22 of 40
Just
benwiddowson
Expert
Message 23 of 40
If you have only got 18 aerial channels maybe worth checking at at800 website to see if 4g is potentially the issue.
Jonty1993
Message 24 of 40
Typed the right way round — now got 43 aerial channels
Anonymous
Not applicable
Message 25 of 40
Is that the same as you get on your TV without the box connected? if so then that's a result
Jonty1993
Message 26 of 40
It’s an attic aerial - have used a signal finder which suggests the signal could be a lot better 59 dBuV
Anonymous
Not applicable
Message 27 of 40
Assuming all the Freeview channels are available in your area (you can check on the freeview website and on digitaluk.co.uk), you would be able to receive many more Freeview channels with a rooftop aerial but you have to weigh that up against the cost which is not that cheap these days.
Jonty1993
Message 28 of 40
I have been informed I have marked this as an accepted solution - far from it
NeilO
Moderator
Moderator
Message 29 of 40
@Jonty1993 I've removed the accepted solution marker from the thread.
srpsrp
Expert
Message 30 of 40
@Jonty1993 wrote:
236816
it’s a shame the package ‘assumes’ you have a Bt router
Curious to know what specific features do you need that BT hubs dont offer ? I can't really think of any off hand, maybe remote login for management but certainly not a lot.
BT are pretty good with firmware updates ( as if their lives depended on it !) An they support BT Wifi / FON which is a fantastic service.
Finally you sometimes get the 'if it turns out to be a fault on your equippment we'll charge you £200' line from them so definiatly don't get an engineer out with out connecting the BT hub !
ISTR you used to have to buy your new router for £100 can't see any problems with BT ones, BT even replace faulty onse for free if you are on contract.
