gmcminn
Message 1 of 5
Do I need an aerial?
We've just made the jump from Virgin to BT and the engineer is coming in a couple of weeks. I don't believe we have a TV aerial but we have perfect reception for BBC1 BBC2, ITV etc. When setting up the new BT account earlier I indicated we did not need an aerial, but now I'm starting to wonder? Does anyone know if we will need one as we get the free channels perfectly at the moment?
4 REPLIES 4
-Richie-
Guru
Message 2 of 5
Re: Do I need an aerial?
Yes an aerial is required for BT TV, what device are you currently watching TV on ?
gmcminn
Message 3 of 5
Thanks for your reply - a Panasonic TV
-Richie-
Guru
Message 4 of 5
I'm guessing it has freeview built in, look at the back and see if it has an aerial in the back, if so then you would connect that to the BT TV box for freeview.
gmcminn
Message 5 of 5
Thanks Richie
