Timshep
Message 1 of 2
Dual output to HMDI & Component/Scart
I am coming back to BT after about 2 years putting up with poor BB reliability with TalkTalk and the chance that BT might actually bring Infinity to a village less than 2 miles from a City Centre!
As BT does not allow multiple youview boxes to be used unless you have Infinity and are prepared to pay twice! (it is fine and free on TT as long as you have a 2nd box (from ebay)) I am being forced to get a SlingShot/Belkin @TV box to send pictures to another device (Son wants Sports in his room - unfortunately no Sky Sports on BT Youview+ unless you have Infinity again).
Can someone please confirm if the latest BT Youview+ box allows output by HDMI and Component (I believe it will have to be via Scart/SPDIF to Component!) at the same time, or will we be forced to get an HDMI splitter with HMDI and Component out?
1 REPLY 1
Moderator
Moderator
Message 2 of 2
Re: Dual output to HMDI & Component/Scart
Hi Timshep,
Thanks for posting. The vision+ box doesnt allow for 2 outputs at the same time via different mediums, it should only channel the picture through one medium.
Cheers
David
Community ModeratorDaveM
Show your appreciation!
Kudos”Kudos”
