Message 1 of 3
Dvd player and youview
Hi there, hope someone can help? We have an old TV which works perfectly with our youview box, and an old DVD player, all connected correctly. We rarely use the DVD player, but yesterday we wanted to watch one so that was fine. All worked well until afterwards when we removed the DVD and switched the player off, I was unable to get my TV to connect again, took me absolutely ages, it seemed like the control just did not work. Normally i get the no signal, I have to press the control to access HDMI12 and then I get TV but it just would not work? Any advice appreciated
2 REPLIES 2
Recognised Expert
Message 2 of 3
Re: Dvd player and youview
Are you relying on the TV to automatically switch back to HDMI2 when you turn on the Youview box connected to it? CEC is always an iffy system and I keep it turned off and rely on my smart remote control to handle source switching instead. CEC is branded different names by different manufacturers.
Message 3 of 3
Thank you for your reply, just watching a dvd now so will try again
