BobWiley
Message 1 of 3
Episode numbers
Hello, I have just moved from EE to BT and can't find a way for the EPG or recorded programs to show me episode numbers, on EE it shows for instance 'S1 E1/10' on the youview it just shows the series number and episode name, how am I supposed to know what episode it is from the name unless I know every episode already? Also when I record an internet channel I can't fw and rw like normal, I understand the difference when watching it live, but why when it's recorded to the hdd can it not fw and rw normally? Thank you for any help.
2 REPLIES 2
gomezz
Recognised Expert
Message 2 of 3
Re: Episode numbers
If you are quick you can spot the episode number being displayed for a split-second before Youview goes out of its way to hide it. Annoying isn't it?
BobWiley
Message 3 of 3
Re: Episode numbers
It must be fast cos I can't see it. It is very annoying, and such a basic thing too, also I believe there's no way to add padding to recordings? Very strange it's missing basic features.
