EHat
Newbie
Message 1 of 2
Error BTP-15000
Hi,
I'm having error message BTP-15000 when I try to access subscription channels via my YouView box. It seems to suggest I am not a BT TV customer but it's showing correctly on my account when I log into the website. Having run through the motions with a person over the phone (turn off and on again, factory reset etc) they suggested an engineer was sent round. I can't see that being anything more than a huge waste of time as it's clearly an issue with my BT account not reflecting my BT TV and BT Sport. The box itself works fine, freeview channels work fine and it can access the internet as I regularly stream netflix through it.
Does anyone know a fix as I'm getting annoyed at having to watch BT sport on my computer instead of on my TV.
AC
1 REPLY 1
Moderator
Moderator
Message 2 of 2
Re: Error BTP-15000
Hi @EHat,
The BTP-15000 usually means there is a mis-match some where in the network with your service. I'll be able to help you get this corrected.
Please can you send me in your details using the "Contact The Mods" link found in my profile?
PaddyB
Community ModeratorPaddyB
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
