woobl
Message 1 of 4
Error IPC 6023 with Time Capsule
Hi all,
I'm using a YouView box connected to a Time Capsule and Openreach modem. However, I keep receiving a IPC6023 error for all the internet connected channels. The TC is set up to connect to PPoE on the Openreach modem, and the YouView says that it is connected, but still no channels. I can connect to the internet on other devices fine.
Does anyone have any ideas on this?
Thanks!
Tags (1)
3 REPLIES 3
trapdoor
Expert
Message 2 of 4
Re: Error IPC 6023 with Time Capsule
The Time Capsule won't handle the IGMP packet type required for the IP Multicast channels. You need a HH3/4/5 or one of the few (and often complex to setup) routers that are IGMP compatible.
Best bet is to do as in my setup - I have a BT HH4 connected to the VDSL modem, my Vision box and YV box connected to this and then the TC/AAE router setup in bridge mode and used as my wifi AP.
woobl
Message 3 of 4
Thanks. I've gone back to using the HH5 with the Time Capsule in bridge mode. However, the trouble now is I want to change my DNS settings which I can't do on the HH - so I'm a bit stuck again!
darrenp
Message 4 of 4
whats wrong with bt's dns servers?
