JJessop
Message 1 of 7
Error code ymv104
Hi. I've been getting this error code for 3 days. Have checked all cables. Restarted. Turned it off and on. What to do?!
6 REPLIES 6
Moderator
Moderator
Message 2 of 7
Re: Error code ymv104
Hi @JJessop
Welcome to the Community and thanks for your post!
Sorry that you're getting the error message on your BT TV service.  Are you any further forward since posting this?  If you're still having problems post back and we'll give you a hand from here.
Cheers,
Robbie
Community ModeratorRobbieMac
Show your appreciation!
Kudos”Kudos”
Moderator
Moderator
Message 3 of 7
Hi @JJessop  sorry you are having a problem with your BTTV service.
Check out What do the BT TV error codes mean? for the error code you are getting and post back and let me know if this resolves the problem for you.
Cheers
John
Community ModeratorJohnC
Kudos”Kudos”
Carlusha
Message 4 of 7
You won't find that error message as you have a transposition error!
You mean "YVM104"  which relates to a YouView box.
JJessop
Message 5 of 7
Hi.  No further forward.  I had a live online chat with an engineer on Monday - nothing worked.  Person said they'd send out a new broadband box and raise a complaint (still waiting for box and the complaint was only recorded on Tuesday!)  thanks anyway.
JJessop
Message 6 of 7
Sorry my dsylexia confused things!
Moderator
Moderator
Message 7 of 7
Hi @JJessop ,
Thanks for posting. We'll be happy to take a closer look at this for you. I've sent you a Private message explaining how you can contact the forum moderation team.
Check here: https://community.bt.com/t5/notes/privatenotespage
If the new box arrives in the meantime and resolves the issue please let me know.
Cheers
David
Community ModeratorDaveM
Kudos”Kudos”
