Pd28
Newbie
Message 1 of 2
Error code
Hi can't get on my tv all channels coming up with code bt-317
1 REPLY 1
Moderator
Moderator
Message 2 of 2
Re: Error code
Hi @Pd28,
Have you got any help with this yet? If you haven't, take a look at the below link:
BT TV error codes
Enter the code 317 and follow the advice given. Come back if you have further problems.
DanielS
Community ModeratorDannyS
Show your appreciation!
Kudos”Kudos”
