Message 1 of 8
Error code?
Hello first time posting basically I signed up for BT landline, Broadband and TV after leaving Virgin media and it all came and I've set it up all correctly but when I've attempted to set up my channels it comes up that I'm not a customer and that I need to ring a number and quote BTP-15000 which I did do. However was on hold two hours and got nowhere I've got two babies so I can't Keep doing that. I've tried resetting it etc but it's not working and just says the same thing please advise. X
7 REPLIES 7
Message 2 of 8
Re: Error code?
From looking back using search it looks like mod help was needed to fix that error so have asked mod to help. They will post here
Moderator
Moderator
Message 3 of 8
Re: Error code?
Hi @Hellchild400,
Welcome to the Community and thank you for posting. I'm sorry you haven't been able to enjoy your BT TV yet. If you send me in your details, I'll be able to help you get that working.
I have sent you a private message with instructions on how to contact me. You can access your messages via the envelope icon at the top right of the screen, or click on this link, Private messages
PaddyB
Community ModeratorPaddyB
Show your appreciation!
Kudos”Kudos”
Moderator
Moderator
Message 4 of 8
Re: Error code?
Hi @Hellchild400  thanks for sending over your details. The BT TV is not working as this part of your order has failed. I have the order team working to fix this for you and will let you know when they have fixed things.
cheers
John
Community ModeratorJohnC
Kudos”Kudos”
Moderator
Moderator
Message 5 of 8
Re: Error code?
Hi @Hellchild400  The team have fixed the BTTV service order now for you. Please can check and you may need to factory reset your box and update the players and apps also. Post back and let me know how you get on.
cheers
John
Kudos”Kudos”
Moderator
Moderator
Message 6 of 8
Re: Error code?
Hi @Hellchild400  Have you had a chance to check if the BT TV is now working ok? Post back and let me know.
cheers
John
Kudos”Kudos”
Message 7 of 8
Re: Error code?
Sorry for late reply! Yes thank you it's up and running perfectly xx
Moderator
Moderator
Message 8 of 8
Re: Error code?
Hi @Hellchild400  thanks for checking that and posting back to me and good to hear it's working ok for you 🙂
Cheers
John
Kudos”Kudos”
