Jodzafin
Message 1 of 2
Error codes btp15000 and btp15990
When setting up the youview box and opening the BT player, I get an error code BTP-15000 (on initial setup) or BTP-15990 (when trying to open BT Player). Customer support do not know what to do and have referred it to another technical department.
A search of previous topics shows others are seeing errors BTP-15000 and BTP-15990. But none of the threads show how to solve it. It seems moderators/employees deal with each case individually. No one actually explains what the issue was (closest explaination i've seen is about accounts not linking correctly?!).
I have copied this post from another because it is exactly the same problem and am also tagging @Gemma_P  hoping that this will get sorted  I've been paying for the service for over 2 weeks now and have been unable.to set up due to the Ariel company through bt being so slow at contacting me, so not happy with bt at all as a first time user!
1 REPLY 1
Gemma_P
BT TV Expert
Message 2 of 2
Re: Error codes btp15000 and btp15990
Hi @Jodzafin,
Sorry to hear you are having problems. If you let me know your account number via a private message and I'll have a look into it for you. Thanks.
