janandrich03
Message 1 of 4
Everything I try to record on channels 300+ end at 4 minutes. It's the same when I try and watch one
Everything I try to record on channels 300+ end at 4 minutes. It's the same when I try and watch one of those channels
3 REPLIES 3
zulu17
Distinguished Guru
Distinguished Guru
Message 2 of 4
Re: Everything I try to record on channels 300+ end at 4 minutes. It's the same when I try and watch
Hi @janandrich03  when watching live  what actually happens after  4 minutes what appears on screen ? do you get an error message ?
Can you also confirm how you have yourBT Tv Youview  connected to your HomeHub.
janandrich03
Message 3 of 4
It says “There’s a problem with your broadband which is affecting History. Check the connection between your box and router. IPC6023”. And I’m connected by WiFi not Ethernet
janandrich03
Message 4 of 4
Actually I got that wrong...they’ connected by an Ethernet cable
