cactusbob
Message 21 of 37
Re: Extra Channel Catch Up Missing
I currently have:
Help & Settings
For You
Library
Bookmarks
Playlist
You're Watching
Catch Up
Rodnork
Message 22 of 37
I am still missing the one at the bottom guess I have to ring them see where that gets me
Distinguished Guru
Message 23 of 37
I have requested that this issue be looked in to
BTLife | 1967 Plus Radio | 1000 Classical Hits
Someone Solved Your Question?
Please let other members know by clicking on ’Mark as Accepted Solution’
Helpful Post?
If a post has been helpful, say thanks by clicking the ratings star.
Moderator
Moderator
Message 24 of 37
Hi Rodnork
Send us an email using the contact the mods link in my profile. You will be able to see this link in the section 'About Me'.
This link will give us the information we need to get this investigated for you.
Stuart
cactusbob
Message 25 of 37
I must add that I did choose the "update on-demand players" option in the YouView settings menu. Maybe that kicked the option back. Not sure that you are missing anything though, there is very little content
Rodnork
Message 26 of 37
I got a little excited as update on demand players I had not done before but unfortunately it not changed anything.
Have sent an email as instructed thanks again for the suggestions.
Guppyfish1
Message 27 of 37
Still no extra channels or extra channel catch up with us either. I lost extra channels on the 17th and catch up from last week.
GF
Community Manager
Community Manager
Message 28 of 37
Hi Guppyfish1,
Can you please send in your details so I can look into this.
Please click on my username (SeanD) and then click on my 'Contact' link which can be found under the 'about me' section of my profile.  Include your BT account details and link to this thread.
Cheers
Sean
Rodnork
Message 29 of 37
Had a phone call this morning from forum support they said they reset something to do with subscriptions turn off box as asked problem was not resolved but now just checking again the catch up is back so what ever you did has worked.
Many thanks
marrio83
Message 30 of 37
Hi I have the same problem, catch up missing in the menu. I have the same TV package and the same box as my parents but they have the catch up on theres. Very odd
