Distinguished Guru
Distinguished Guru
Message 1 of 2
Extra Channels Catchup
Back in Octiber (7th)  it was reported on the forum that
BT was iin discussions to bring catch up from Universal and Syfy. Although no date was specified it was expected to be within a couple of months.
Is this still happening ?
Also when BT issued its press release (Nov 8 2012) that
The agreement with British Eurosport will also give Vision viewers a range of top sporting content to watch anytime through catch-up programming.
To date none has been provided..Given the flexibility of Eurosport schedules as sports overrun get delayed etc and the inflexibility of the recording system to allow padding of recordings it would be good to have the fallback of catchup programming.
Is there any progress on this ?
1 REPLY 1
Moderator
Moderator
Message 2 of 2
Re: Extra Channels Catchup
Hi zulu17,
Thanks for posting. I'll chase this up and get back to you as soon as I have anything.
Cheers
David
Community ModeratorDaveM
Show your appreciation!
Kudos”Kudos”
