Message 1 of 4
Extra box
I have been given a brand new unwanted BT box by a colleague.  I know there is the Multi Room option Package from BT for an extra fiver - but as I have the box I wanted to see if I could just rig it up and use it to record without upping my subscription.  I currently link my main Box using power Powerline adaptors - so if I invest in another set could in theory plug in the 2nd box or would the hub block it as I haven't got a 2nd subscription?  I'm not bothered about using it for streaming any on-line content, just to record terrestrial TV to watch later.
Thanks for any tips.
3 REPLIES 3
Message 2 of 4
Re: Extra box
Ah - I have found another thread where people say it can be used as a freeview recorder with no internet connection.  But not sure about the EPG - if that'll work?
Message 3 of 4
Re: Extra box
@bc909885
I run 2 Youview boxes without any TV subscription and the only thing I can't get is the subscription channels - everything else works exactly as it should do. The BT TV app also connects to one of those boxes quite happily.
Message 4 of 4
Re: Extra box
Thanks Tim - I'll give it a go and wire it up tonight.
