Rodnork
Message 1 of 6
Extra channels Catch Up TV menu Option missing
The Catch UP TV menu option has disappeared.
Was working and can still watch programs if manually search for them though a real pain.
5 REPLIES 5
Distinguished Guru
Distinguished Guru
Message 2 of 6
Re: Extra channels Catch Up TV menu Option missing
You could try a
  • power cycle: put the box in to standby, then turn it off completely at the back (or failing that the wall socket), wait about 20 seconds, now turn it back on and power it up.
make sure the box is not recording (or about to record) when you perform the process.
Rodnork
Message 3 of 6
Tried that it did not work
Rodnork
Message 4 of 6
Has this menu option been removed or relocated ?
scointer
Recognised Expert
Message 5 of 6
Rodnork, take a look at this thread and see if it is anything like your issue.If it is you need to get a mod involved..
https://community.bt.com/t5/YouView-Boxes/Extra-channel-players/m-p/1290595#M12736
Rodnork
Message 6 of 6
Thanks for the reply tried that and have PM one of the mods
