VrNick
Message 1 of 5
!!FIXED!! House sitter turned off all plugs while I was away. Now BT TV has no internet.
As above,
Went away for 7 days and had house sitter. Came home to all plugs turned off something I never do.
Now my BT TV BOX has no internet connection.
All other devices do including the Smart TV the box is plugged into.
Any help appreciated.
Thanks, Nick
Tags (1)
4 REPLIES 4
Message 2 of 5
Re: House sitter turned off all plugs while I was away. Now BT TV has no internet.
@VrNick
If the Internet connection is fine on other devices, how is the BT YouView box connected to the BT Home hub?
Is it a direct cable, or are you using the BT Mini Connectors?
VrNick
Message 3 of 5
Hi it is done via BT mini connectors.
One the box ids plugged in to is flashing blue and red, I read that as mixed internet speed?
Many Thanks
Nick
Message 4 of 5
VrNick
Message 5 of 5
Had done the reset, however when reading through the link I swapped both connectors over and now It works, bizarre but not going to complain.
Thanks for all the help 🙂
