I'm wondering if there may be a bug in this update. Twice since the update a series link has recorded a programme then immediately deleted the series link.
I noticed the series link for Frasier had been deleted. I went into the planner to put it in again. However, I noticed that after I was asked if I wanted to record the series or the single episode, pressing series did not produce the 'series link' icon but just to record the one episode.
Minutes later the single episode recording had changed to 'series link' but only as far as this coming Sunday. For Monday and the rest of next week there were no recording reservations at all for Frasier. I then entered a recording reservation manually for every day next week. About ten minutes later the single reservations had changed to series link.
Now you could claim this was a CRID error by C4. However, the same recording reservation was still there in our Freeview+ PVR and the reservations were there for the rest of this week and the whole of next week too.
@Stevek1311wrote:
@Jim-ladwrote:
@Stevek1311wrote:Radio recordings are still failing. They appear to record but there is no sound which for a radio recording is the only key bit really
I have to confess it's not something I do. I have recorded a radio show 'once' using my Freesat box. However, as there is now BBC Radio iPlayer plus lot's of Podcasts available it's not really an issue. So long as I get my weekly fix of The Archers I'm a happy bunny.
Ah but a programme only gets to iPlayer after it's finished.
You can chase play a radio programme while it is still being broadcast by using the browser version of iPlayer Radio on your phone or tablet or computer. Been doing it the past couple of days while listening to TMS when I can't get a decent DAB radio signal and had to catch up over the lunch interval on my phone.
(yes, I know I could use the BBC Sports app to chase play the commentary but that plasters live state of play spoilers on its play screen)
Thanks Gomezz will try that
@Stevek1311wrote:Thanks Gomezz will try that
And it works - thanks!
I had something similar happen with recordings of law and order on 5USA, the series link first disappeared, then when I tried to reset it, the icon didn't show as a series link. About half the future episodes weren't set to record at all, the rest had no record icon but were shown as scheduled to record when I looked at the info for an individual episode. Same thing happened with reverie on Syfy and Castle on your tv.
On a couple of other shows the record icon failed to appear at all but the shows did record.
@w2pixelwrote:I had something similar happen with recordings of law and order on 5USA, the series link first disappeared, then when I tried to reset it, the icon didn't show as a series link. About half the future episodes weren't set to record at all, the rest had no record icon but were shown as scheduled to record when I looked at the info for an individual episode. Same thing happened with reverie on Syfy and Castle on your tv.
It does appear this update fix may have inadvertently introduced yet another bug. Not encouraging.
Actually my problems started before I got the update, so I'm not certain it's the cause. In addition to getting these issues I had other problems with series links not working properly, like I posted about before hopefully it doesn't go on as long as the fail to record error.
We are still experiencing lots of failed to record programmes and since we signed up primarily to be able to record programmes this is becoming increasingly frustrating. I'd be grateful for any advice/assistance anyone can give. Thanks.
@KJC1wrote:We are still experiencing lots of failed to record programmes and since we signed up primarily to be able to record programmes this is becoming increasingly frustrating. I'd be grateful for any advice/assistance anyone can give. Thanks.
If you're able to just try disconnecting it from the internet OR
set the smart stanby times to the same time , so no deep sleep period as the problem might be triggered by coming out of deep sleep & accessing Youview's servers.
Both work for me
