Recognised Expert
Message 511 of 535
Re: Failed Recording
Got the 31.28 update today so I've now switched off all my tricks & gone back to normal, let's see how that works.
Expert
Message 512 of 535
All the evidence is you should be optimistic
on this particular issue
Expert
Message 513 of 535
Failing that just settle for being an optimistic pessimist. Smiley Happy
Recognised Expert
Message 514 of 535
I'm mostly a glass half full guy but with Youview.....
Message 515 of 535
Had two failures tonight Holby on BBC 1 and Conviction on Pick, slightly different behaviour than previous failures, both times the box was on but when the scheduled recordings were due I got the "x programme is now recording" notice, then the box switched to the channel it was supoosed to be recording, but the record light didn't come in. When I looked in Mytv, it said the shows were recording, but they weren't. I wasn't recording anything else at tgat time, so the box shouldn't have needed to switch channels. Conviction failed last week too, so I cancelled the old series link and rescheduled after the update.
Expert
Message 516 of 535
That doesn't sound like the behaviour associated with the failed recordings issue.  I would think this is an unrelated problem.  Are you sure that Conviction was actually on or had it been moved/replaced by something else.  You can cycle back through the EPG to check this.
Message 517 of 535
Hi,
Is there a schedule for the 31.xx update. I have a 2100 box, and still on 29.58 , and is now 2 weeks since release.
Chris
Recognised Expert
Message 518 of 535
Yes there is but nobody knows what it is.
I'm afraid that you just have to be patient a little longer.
Message 519 of 535
Yes both shows aired as scheduled, no need to check the EPG, as I saw them when the box switched channels at the time the recordings were due to start.
Expert
Message 520 of 535
I would say if it continues to occur you need to phone BT as what you are describing is not what was happening with the failed recording issue.  For a start the box wouldn't switch channels to record as it simply wasn't getting the information it needed to recognise there was actually a scheduled recording in place.
