Message 91 of 535
Re: Failed Recording
@ItFixer wrote:
I'm having exactly the same problems with random failures in recording but it's happening more frequently.
I contacted youview & they just said do a factory reset (already done) then do a retune (again had already done) then they blamed my signal which I showed them was 100% for both strength & quality
Please read this information Picture breakup or missing FreeView channels
It would also cause lost recordings
You will need to connected to BT Broadband to access any links I post which are hosted on my website..
If you are connected to BT Broadband, and you cannot access them, then please let me know on this thread. Thanks.
ItFixer
Message 92 of 535
To add to my previous post
All failed recordings happen when the box is on standby mode
All recordings were series linked through the guide
It seems like the epg fails to update causing the programme to fail to record (because the box doesn't know the program has started) and when you turn the box on the epg updates & so it shows fails to record or it will start recording if the program is still on
Jim-lad
Expert
Message 93 of 535
@Johns_WH yep we've had a number of very short recordings too. Some of these programmes have started to record just a few minutes for the scheduled ending, most annoying. Don't think it's anything to do with the transmitter either.
Jim-lad
Expert
Message 94 of 535
@Keith_Beddoe is correct re: tuner overload. However, I know that isn't the issue in my case. We get 100% signal quality on all muxes but signal strength can vary from around 30% on COM 7 & 8 channels 55 & 56 to 90% on the PSB mux.
Some of the failed recordings on the BT box have recorded without issue on our non-BT PVR.
TimCurtis
Recognised Expert
Message 95 of 535
Neighbours and Home & Away on Thursday lunchtime on OldGen - 26.41
Jim-lad
Expert
Message 96 of 535
I've just noticed I've had three more failed recordings this morning.  Frasier on series link C4 in SD, these are or should have been back to back series link recordings, all failed.  Box in SMART standby at the time.
This issue really is getting beyond a joke now and I'm afraid if BT can't find the problem (and the solution) in very short order indeed then I will be looking to get an early release from my Youview contract.  I'm not going to phone up their call centre only to be treated like an idiot i.e. reset the box √, reboot the router √ check ariel and cabling √.
I have done all these and it's not made on bit of difference.
NathW
Newbie
Message 97 of 535
Hi,
DTRT2100, Model 91-00438, London
26/5/18:  Failed to record F1 qualifying and P3 although did record P1 and P2.
29/4/18:  Failed to record F1 pre-race and race but did record the post race reaction.
This is pretty much all we have setup to record (using series link, Channel 4 HD) so I don't have any other examples.
Doesn't seem to be very random insofar as it manages to fail on the only bits I actually want to watch!
nickmorc
Message 98 of 535
Getting exactly the same issues on my BT UHD Box, cant trust to record anything. Very disapointing, hope BT get this sorted soon.
berno
Message 99 of 535
Yet another failed recording today. The Coronation BBC1 HD 5:05PM today.
Maybe it’s time to contact Watchdog. We are paying for a service and BT are not delivering. 😡
bobkon
Message 100 of 535
You are right this has gone on long enough, come on BT get it sorted. Maybe contacting Watchdog would be a good idea, what do others think.
