Stevek1311
Expert
Message 481 of 535
Re: Failed Recording
Radio recordings are still failing.  They appear to record but there is no sound which for a radio recording is the only key bit really
Jim-lad
Expert
Message 482 of 535
I have to confess it's not something I do.  I have recorded a radio show 'once' using my Freesat box.  However, as there is now BBC Radio iPlayer plus lot's of Podcasts available it's not really an issue.  So long as I get my weekly fix of The Archers I'm a happy bunny.
Stevek1311
Expert
Message 483 of 535
Ah but a programme only gets to iPlayer after it's finished.  And not all get to iPlayer.
There was a previous thread on this but the originator bizarely marked it as solved just because there was a promise by YouView to maybe get round to fixing it one day.   And we know how worthless those sort of YV promises are
So unsurprisingly they haven't and so I now have an ever growing stack of failed radio recordings.
Keyinferno
Message 484 of 535
Until such time....Press pause and then play.
Jim-lad
Expert
Message 485 of 535
Well as said, I have a couple of Freeview+ PVRs and Freesat so it's not something which really affects me.  If the fix solves the failed TV recordings then that will do me.
Krisb60
Message 486 of 535
The fix seems to have resolved the problem on my T1000
But the box has become very slow at startup and between menus ....
Stevek1311
Expert
Message 487 of 535
Doesn't change anything.  Still no sound
TimCurtis
Recognised Expert
Message 488 of 535
@Jim-lad
Well your deep sleep change seems to work ok on my T2100.
So there seem to be 3 ways of preventing failed recordings:-
1. Turn off deep sleep - start & end times the same. May not work on all models.
2.Permanently disconnect from the internet
3. Block daily internet access until after the first recording of the day has started.
I've been using 2 & 3 for several weeks now without any failed recordings.
Jim-lad
Expert
Message 489 of 535
@TimCurtis - you should hopefully have the update by now and if not then within the next few days.  Certainly altering the SMART standby settings worked for me too.
TimCurtis
Recognised Expert
Message 490 of 535
Not yet unfortunately
