John22
Message 1 of 2
Failed recordings
Does anyone still know when the software for model number 2110 will be realeased or has updates finished now
1 REPLY 1
TimCurtis
Recognised Expert
Message 2 of 2
Re: Failed recordings
The update is released now for the T2100 , T2200 & T4000.
Assuming the T2110 is included within the T2100 range then hopefully you'll get an update within a couple of weeks. There's is now way to get an accurate estimate of it's arrival on your box unfortunately.
