Spewy
Message 1 of 4
Failed recordings
Hi All,
My series recording aren't working, well some aren't. This has only occurred over the past few days.
I have searched on here without success, threads being closed due to software updates mostly.
Retuning and resetting hasn't worked.
I cnat even get the 'record symbol' to appear or disappear on some.
Thanks in advance for the help.
3 REPLIES 3
BT TV Expert
BT TV Expert
Message 2 of 4
Re: Failed recordings
Hi @Spewy
Sorry to hear you are having problems with series recordings. If you're able to send me your telephone number via a private message I'll have a look into the problem for you. Thank you,
Gemma
BT TV expertGemma
Show your appreciation!
Kudos”Kudos”
I am a BT Employee and an expert on TV queries. I am here volunteering my own time to give advice, and help where I can with BTTV queries. Go here for more info.
gomezz
Recognised Expert
Message 3 of 4
One common reason for Series Recordings to fail is down the broadcaster messing up the tagging of episodes that belong to a series. One thing to do is to delete the existing Series Recording and set it up again.
Spewy
Message 4 of 4
Factory reset worked
