John62
Message 1 of 4
Freesports
I’m unable to access Freesports through by BT HD box.
Channel 64 is not there in the channel list. I have tried retuning and checked for hidden channels.
I can access it when I plug my cable from the wall directly into the tv and bypass bt so it is available but for some reason not through my bt box.
any ideas? Thanks
3 REPLIES 3
NigelB72
Recognised Expert
Message 2 of 4
Re: Freesports
Can you recieve other channels on the same mux?
ken2222
Message 3 of 4
Re: Freesports
We sport neither what I've been hearing it's to do with con 7 if there's channels on them frequencies it's very hard to get I've been told by the Freeview people when I phoned them up about this I were thinking it out putting it on con5 yes I did I think you would have got it it but instead they decided to put it in the mix con 7
NigelB72
Recognised Expert
Message 4 of 4
Re: Freesports
Freesports is on Com7 so turn to another channel on Com7 such as Quest Red+1 and check what signal strength and quality you are getting
