John22
Message 1 of 3
Freeview bt 2110 box
Something strange has just happened to my freeview bt 2110 box i was watching a recording on central tonight it came to the end i pressed the stop button. Nothing happened pressed fast forward same again nothing pressed the blue youview button on the remote nothing. the only button that worked was the standby on off button left it for about 15 mins and everything is working again any ideas thanks
2 REPLIES 2
speedyrite
Distinguished Member
Message 2 of 3
Re: Freeview bt 2110 box
Like most tech stuff, performance issues can occur as "uptime" becomes high and it probably just needed a restart (be it a full reboot or just sometimes "turning it off and on again") to get back to normal.
John22
Message 3 of 3
Yeah thanks for advice i done that last night turned it off and took plug out of power. Lets see what happens to it now
