justracing
Message 1 of 8
Freeview channels
I'm completely new to BT, we've just moved house and we have a youview box all hooked and working with wifi but I can't find freeview anywhere. Specifically I'm looking for the Freesports channel, can anyone help please? I confess I'm struggling to navigare my way round with this system as we have Virgin cable for 25 years.
7 REPLIES 7
Message 2 of 8
Re: Freeview channels
Welcome to this user forum.
Have you got a good signal from a TV aerial, plugged into the back of the YouView box, as that is how the FreeView channels are delivered?
See this guide http://bt.custhelp.com/app/answers/detail/a_id/53540/~/setting-up-bt-tv
justracing
Message 3 of 8
The aerial signal is fine, I have the aerial plugged in the back of the youview box, if I swap the aerial and connect it directly in the tv I have as a good picture.
justracing
Message 4 of 8
I've reconnected the aerial into the box and retuned the channels, how do I find Freeview please?
Message 5 of 8
The channels you see, like BBC1, ITV etc, are the FreeView channels.
justracing
Message 6 of 8
Thanks for that, everything works in that regard but I can't find the FreeSports channel, according to their website it should be channel 64 but this shows as no channel.
Message 7 of 8
Some transmitters do not carry all the channels, especially if its a local repeater.
Look up your postcode on the FreeView website, to see what channels are available at your address.
gomezz
Recognised Expert
Message 8 of 8
Note also that COM8 is on a lower power from the transmitter so you may not pick that up if on the fringes of the reception area. COM8 is the MUX Freesports is on.
